RCU Forums - View Single Post - YS-170 Problem
Old 12-27-2008 | 03:18 PM
riot3d
Default RE: YS-170 Problem
Before your first run, put a little fuel into the engine through the plug opening. Flip it over a bit, then, use a starter to spin the engine without the plug. Basically, you want to soak the inside with fuel to dissolve the lubricant that came with the engine.
Works every time.
Adrian
