Cheap and easy in air ??
Thanks for your replys thay was all usefull (except rc_sport)
I have allready found a used radio set I can borrow for as long as I like, lucky me !
I got a few servos big and small on stock from old car/robot projects, so I am ok there also.
To fast sky:
>If you try to fly on your own, any plane will probably crash
> on you in less than a minute and you proably won't even
> know what happened!
Thanks hehe, but I have allready flown a few times, even started and landed, both gasoline and El..
I must say the EL types are more appealing to me so far.
To Taildragon: YES you are right.. I visited two of the major shops here en Copanhagen, wow.. it can be expensive !! I will try a cheap el-slowflyer with high V shape wings, and the borrowed radio system. then I can find out if I dont like it.. or maybe even get totally plane-crasy, then I dont mind using a small fortune on it, if I really like it you see..
