ORIGINAL: Mad Racer
Well, I don't know if they are bad or good, but I am working so hard to found the rubber seal BB's in around Canada. The only ones I found are BB's with plastic like material or fiber glass that is on both sides of the BB, they will do a good job keeping dirt and dust away from the insides of the BB, but they won't work against water, they will still get in the BB. Guess it's last resort, bushings. [:@][:@][:@]
http://cgi.ebay.com/Kyosho-EP-Blizza...3286.m20.l1116 I think you're mind gaming yourself on bearings. Most go with this seller ... cheap & fast shp'g. Read his info and pick the set you need. All I do is blow the blizzard off and take it inside. No problems at all.
