RE: AquaCraft Alligator RTR
Yep it was spinning ccw. I usually expect most new nitro engines to have tight compression until they are broken in. This engine doesn't. So if the choke method fails then it's back to Tower. Did you have to "choke" your engine or did you just make sure your fuel line was full of fuel and it started right up? Was the compression kind of tight or kind of loose before breakin? Since you said that yours started right up it makes me believe that this engine may be bad. If you say that your engine had tight compression until breakin then it'll confirm my suspicions.
