ORIGINAL: av8rk
Do any of you guys know if i must create a condition before i do a program mix with the 12FGA?.....I want to use the rudder channel as the master & the steering servo as the slave.....I want to have the nose wheel steering servo inoperative in the retracted position.....I can do it blindfolded with my 9ZWC2....but no luck so far with the 12FG
Rich
Rich, you do not need a condition to do this. All you have to do is setup a Pmix using rudder as master and steering as slave with the retract switch as the on/off control switch for the mix. Gear down would be the Pmix 'on' setting and gear up would be 'off'.
Woodie
