RCU Forums - View Single Post - Supplement Code 550
Old 12-28-2008 | 03:31 PM
typicalaimster's Avatar
typicalaimster
Default RE: Supplement Code 550
Which in regard to the Primary / Secondary control. The AMA told me they'd revisit the issue in the future. Right now they want to roll it out the door and see what impact it has. I'm still a huge advocate of having a spotter if you're flying FPV at a AMA field. Once you have the video goggles on, you have no situational awareness of other models flying around you. It's nice to have someone there to help spot you should danger arise. To me if you crash your plane because you went to far out, that's your own fault. However if someone else at the field has lost control and may crash into you or the pits.. I want someone there to pull me out of the way!
