RE: trex 450 sa setup
I think with the 13 t pinion your getting a bit over 3000 rpms at the head (between 3000 & 3200 depending on your motor). You should really try a 12t pinion which will give you 2800 to 3000. Most blades are only rated to 2800rpms, so be very careful.
