RE: trex 450 sa setup
When I first got my SA I used the 11 tooth. Depending on what battery you use you can expect about 2600 to 2800 rpm. That's plenty for hovering and forward flight. You'll also get longer flight times over the 12 or 13 tooth. If your just starting out, longer flight times are preferable over very high head speeds.
