RCU Forums - View Single Post - Echo saw conversion help
Old 12-28-2008 | 09:32 PM
av8tor1977's Avatar
av8tor1977
Default RE: Echo saw conversion help
Usually the chain saw engines are in a pretty good state of tune for our uses as they come; especially a high grade one like an Echo. About the only thing you might do besides using a free flowing exhaust is to check and make sure the exhaust timing is around 150 degrees more or less. The original carb, if it is a two mixture needle model will probably work fine.
AV8TOR
