RE: Changes to Experimental Regs
So according to rule #2 I can no longer put a 37lb or 43lb thrust turbine in say a 28lb Eurosport or boomerang??? And are we going to go by manufacturer rated thrust or actual thrust produced by the aircraft since in situations where a bifurcated pipe is installed the aircraft actually looses thrust??
