RE: spark plug compression leak
What kind of engine do you have and what kind of plug are you using.Did you buy it used?Are you using a 5/8 peanut plug with a taper seat in a standard plug with a flat gasket.If its the flat gasket type is the plug gasket even there?
Are you sure the plug isnt cracked?
