RCU Forums - View Single Post - spark plug compression leak
Old 12-29-2008 | 10:58 AM
av8tor1977's Avatar
av8tor1977
Default RE: spark plug compression leak
The Zenoah glow plug adapter has a taper for a taper seat; no gasket. His engine probably had a gasketed spark plug.
You can try adding a gasket. Another way would be to machine a short taper in your head to match the taper of the glow plug adapter. I don't recommend any sealer...
AV8TOR
