RCU Forums - View Single Post - BVM FJ-2 Fury Build
Old 12-29-2008 | 11:00 AM
k_sonn's Avatar
k_sonn
My Feedback: (32)
Default RE: BVM FJ-2 Fury Build
I measured and cut out the main gear door openings in the bottom of the fuse. The wing mounting formers were assembled from carbon and plywood pieces. The wings were fitted to the fuse and the wing mounting formers were hysoled in place. The fan mounting structure, gear door mounting structure (the air cylinders and hinging mechanisms will be mounted to this structure), and elevator servo mounting structure were built and installed. Based on the instructions, the fan needs to be installed while the hysol for the fan mounting structure is setting. In order to do this the nose had to be glued in place and the intake ducting temporarily installed. After that, the fan was installed. Current weight of the fuse with everything I've done up until now including the installed fan and the nose retract and strut is 5 pounds.
Kirk
Not a BVM rep, just a very satisfied customer
ID:	1098778   Click image for larger version
ID:	1098779   Click image for larger version
ID:	1098780   Click image for larger version
ID:	1098781   Click image for larger version
ID:	1098782   Click image for larger version
ID:	1098783   Click image for larger version
ID:	1098784   Click image for larger version
