RCU Forums - View Single Post - Hangar-9 Sopwith Camel Build Thread
Old 12-29-2008 | 01:48 PM
  #476
phatbob02
My Feedback: (126)
Default RE: Hangar-9 Sopwith Camel Build Thread
ORIGINAL: CGAMT
Bob,
I had another question concerning the ailerons. while testing my radio i found that when i make a right turn my right aileron goes down. Knowing a little about aerodynamics this would cause more lift on the right side making the plane turn left. Is this how you control a model airplane or do i have my ailerons installed incorrectly? i Also thought maybe since it is a model that this would be normal since a model does not fly at the same speed as a real aircraft and that the downgoing ailerons would cause more drag making the right side of the plane move slower causing the plane to turn right when the right ailerons goes down. Thanks.
Jeremiah
Jeremiah
You have the ailron servo reversed. You should have a switch on your radio to reverse the servo. On a right turn the aileron on the right side would be in the up position forcing the right wing down. The left aileron would be down forcing the left wing up.
I'm new on this thread and just finished my Sopwith. Forgive me if I'm wrong but what I'm reading is that this is your first rc aircraft and your in for a rude awakining. The Sopwith should be your 3rd or 4th aircraft, not your first.
Bob
