RCU Forums - View Single Post - FASST signal voltage compatability
Old 12-29-2008 | 03:06 PM
Ehab
My Feedback: (44)
Default RE: FASST signal voltage compatability
ORIGINAL: MikeMayberry
Only a small percentage of the digtial servos did not work; analogs are fine. The only way to know is to plug them in. If you find some that don't work then send them in to be updated.
Mike.
Has this been tested at higher temps? The reason I ask is because Futaba's advisory warns that some servos will work ok till the temps go up, then (I assume) the 6014 specifically may have a lower signal than 2.7v...
Just to let you know, I have been using hitec digi servos in my jets with the 6014 with no problems, BUT I am using a small 5v fan to keep the Rx cool...
