ORIGINAL: snappa
well done! Now did you have the control rods installed or did you do something else?
If your asking if I used the stock control rods for rudder and elevator, the answer is kinda, but not really. I did use the black fiberglass rod things, but, only as a control rod guide tube. I used 4-40 dubro control rods from servo horn to control horn. The tubes were simply glued in place and the 4-40 run inside it.
