CA Hinges
I don't flex the control surface before dropping the ca. I find that I can get more consistent gaps by placing round headed pins (the ones you put on the notice board) in several points along the gap. The round plastic heads keep them from falling thru the gap. Slight flexing may be done to facilitate ca application. In any case I seal the gaps with clear monokote.
