RCU Forums - View Single Post - Jet Pipe Issue
Old 12-30-2008 | 09:09 AM
ECalderon's Avatar
ECalderon
Default Jet Pipe Issue
Hi Guys
I was installing the jet pipe in my jet and I noticed that one of the mounting tabs is not as firmly attached as the other.
Here are pictures of both mounting tabs. In the good one you can see that it lies flat against the surface of the pipe and that there are several soldering points.
The one with the problem doesn´t lie flat and there are fewer soldering points and it feels relatively loose compared to the other one.
The question is, can I just drill a hole and put a bolt, washer an nut to attach it more firmly?, would this bring me problems in the future? what would you guys do in my case?.
Regards Eduardo
ID:	1099500   Click image for larger version
ID:	1099501   Click image for larger version
ID:	1099502   Click image for larger version
ID:	1099503   Click image for larger version
