RCU Forums - View Single Post - Pattern plans (.60-.90)
Old 06-04-2003 | 05:31 PM
MrSteve09
Default Loaded Dice II
Gerry,...
Very nice job on your Loaded Dice II. I especially like the way you shaped the cowl to blend with the spinner. That was the major thing I didn't like about the design was the way Terry Westrop had only a prop nut on the front of the plane. Even if he did put a nose cone on the front, the cowl just didn't look like it would blend in very nicely. But as you've proven things like that can be changed to be aesthetically more pleasing.
Another question I had about the design is,... what canopy does he use?? Did you use the same canopy or substitute something else??
Once again,... very nice job. Guess I'll have to give the Loaded Dice II another look!! What engine are you using in your L.D. II??
Sincerely,
Steve T.
Monson, Massachusetts
