RCU Forums - View Single Post - You will not believe this!!!!!
Old 12-30-2008 | 04:53 PM
  #57
basman
Default RE: You will not believe this!!!!!
ORIGINAL: ppkk
Zeeb,
Thanks for the informative posts, I will go and check my two receivers to see if they have the update - and do a rebind while at it...
I have a question regarding 6V batteries and servo life: when installing a 6V battery, do you use a step-down device to bring voltage to the servos down to 4.8V or leave it at 6V? Sorry for the basic question, still learning my way around RC's.
Thanks.
I asked the same first time i went to a 6v in my 120sise extra. I told to check the servo specks to see if they run with 4.8v or 6v. The servos I was using worked in a range from 4.8-7.2v
