RE: 50cc Sukhette Build Thread, now in progress!!
I've been using coated and uncoated pull pull cables for years with 72mHz, no interfrence, so what's the problem? If I go out and order a carbon wing tube for a $1,700.00 Comp Arf I have to trim it, so what's the problem?
The only real complaint I can see here is the wing not fitting and the landing gear mounting holes, but mine matched up just fine when I trimmed the gear opening about 3/16". Did you make mention of the wing fit to Tom? If not I'm sure nothing was ever done about it. If you did I'd be surprised if nothing was done about it.
