RCU Forums - View Single Post - G2 - Tail spinning counterclockwise
Old 12-31-2008 | 01:37 PM
owinfrey
Default G2 - Tail spinning counterclockwise
Hi All,
I have a bushed G2 raptor and it started tail spinning counterclockwise.
I did the gear test by holding the tail rotor and turning the main rotor.
There was slippage, so I replaced the tail gear in the set "50H08-26 Gear Set".
It still spins counterclockwise.
I reset the gyro settings using #12 dip switch and V2 per manual, same results.
The belt's teeth looks fine.
The gyro switches are set to normal and reverse
If I change the gyro switch from reverse to normal I have better control of the tail rotor, but in reverse control.
Transmitter switches are on for 2,4,6,7 on and the rest are set to off.
Any suggestions?
