RCU Forums - View Single Post - AMT BA's Concorde
Old 01-01-2009 | 11:42 AM
  #47
Jerry K
Default RE: AMT BA's Concorde
[quoteyou can go and if you are flying on your own then AMA doesn't have anything to do with anything!][/quote] That is not nessarily true.The way I remember it is that if you violate the conditions of your waver anywhere anytime, AMA field or private land you risk having your AMA issued waver revoked. The issue is not weather you can fly on your own land it is weather you can fly under the AMA umbrela, ever again. Keep in mind Flying under AMA is a privlige not a right which can be revoked at any time. This has been disgussed in the same context about a year ago in the same type of thread about Jim's plane.
Jerry
