RCU Forums - View Single Post - common arf mistakes?
Old 01-01-2009 | 12:29 PM
FallDownGoBoom
Default RE: common arf mistakes?
Use acetone (which I think is best), available in the paint section of your local hardware store. Or you can use 100% isopropyl alcohol, which is available at drugstores. You want to avoid adding water from the alcohol to your epoxy mix.
