RE: YS63S
It could be dirt that is keeping the plunger inside the regulator forced open. You will need to take apart the regulator and clean it well. You also could try to run it several times. Sometimes the plunger will get clean by fuel passing. I am sure that others with a lot of experience in this engine will give you more detailed advice.
Good luck and Happy New Year,
Vince
