RCU Forums - View Single Post - YS63S
Thread: YS63S
Old 01-01-2009 | 02:52 PM
apereira's Avatar
apereira
Default RE: YS63S
I checked one form a fellow modeler that had the same problem, it was a bad o ring on the valve pushrod tube, these engines need to have absolutly no leaks, you can run it and look for leaks (be very carefull!!!), the whole engine is pressurized so any leak will cause problems.
If in doubt, change the o rings with new, and after that adjust the regulator only if necessary.
