RCU Forums - View Single Post - SSE Incidence issue during build
Old 01-01-2009 | 06:40 PM
SeamusG's Avatar
SeamusG
Default SSE Incidence issue during build
I'm about the mount the stab to the fuse per the old instructions. With the wing mounted I aligned the stab trailing edge with the wing trailing edges (again per instructions). Before I epoxy the stab to the fuse I tossed an incidence meter on the wing and stab. The wing relative measurement is 4 degrees positive and the stab is 1 degree positive. They should be the same. To achieve 4 degrees positive on the stab it will be necessary to raise the forward edge of the stab 7 mm (over 1/2"). Of course the rear can be dropped the same.
OK peanut gallery, how would you approach achieving the same incidence on the wing and stab?
Thanks for you learned feedback.
