RCU Forums - View Single Post - Helimax 400 3d
Old 01-02-2009 | 05:06 PM
  #47
electron's Avatar
electron
Default RE: Helimax 400 3d
Great Video... Thank you and really great flying BTW ! I am really hyped to get mine up and flying now.. I spent at least 6 hours last night trying to get the transmitter setup and there is still something wrong with my settings Urrrrrrrr... I cannot get the swash to act correctly.. On throttle/collective all three servos seem to be working correctly and the rudder seems to be fine but not sure about the gyro yet will have to spin it up for that...
But on the left/right and forward cyclic all seem backwards as I move the stick up and down and the swash moves left and right and then if you give the radio a left and right on the stick gives you this weird 25 degree tilt left and right.. I have moved the servo channels all around on the TX a dozen times and I still can't get it to move the swash correctly...
Hopefully someone on here can help me out with what is going on.. Here is what I have currently setup on both the RX and TX...
On the RX
Aileron CCPM on Channel 2
Elevator CCPM on Channel 3
Tail Rotor on Channel 4
Gyro Gain on Channel 5
Collective CCPM on Channel 6
Throttle on Channel 1
Transmitter Setup
Swash plate type
3 servo's 120 degree
D/R & EXP
Aile
Pos-0
EXP +20
D/R 100%
Pos-1
EXP +15
D/R 80%
Elev
Pos-0
EXP +20
D/R 100%
Pos-1
EXP +15
D/R 80%
Rudd
Pos-0
EXP +35
D/R 100%
Pos-1
EXP +25
D/R 70%
Servo Reversing
Channel
1 Norm
2 Norm
3 Rev
4 Norm
5 Norm
6 Rev
Travel Adjustment
Rudd
L 90%
R 90%
Swash plate mixing
Aile +65
Elev +65
Pit +80
Throttle Hold
Hold SW 0.0%
Throttle Curves
Norm 3 Curves 0.0-50%-100%
ST-1 3 Curves 100%-85%-100%
ST-2 3 Curves 100%-100%-100%
Pitch Curves
Norm 3 Curves 35%-50%-100%
ST-1 3 Curves 0.0%-50%-100%
ST-2 3 Curves 0.0%-50%-100%
Hold 25%-50%-100%
Gyro Sensitivity
Auto
Rate
0 70%
1 70%
Timer
7 minutes
Any help would truly be appreciated..
Electron
