RE: CEN Matrix Bearing inside Steering Knuckle
In the front it uses - 8 x 16 x 5mm bearings, they're all the same size in the front, and in the rear it uses 2 inner bearings - 15 x 24 x 5mm and outer is the same size as the front ones. Hope that helps.
