RCU Forums - View Single Post - spark plug compression leak
Old 01-03-2009 | 01:47 AM
av8tor1977's Avatar
av8tor1977
Default RE: spark plug compression leak
Well, glow plugs come in heat ranges as well, and this is how the ignition timing is "set" on a glow engine. So if the glow plug and it's adapter aren't flowing heat into the head properly, the glow plug would run hotter than normal, and advance the ignition. Possibly to the point of causing problems....
AV8TOR
