Hi guys,
Here are some pics of my build so far:
you can see the tank in the "stock" position, which is at a fairly steep angle, and then when I have positioned it horizontally. In the horizontal position, the front of the tank is too low to poke through the fire wall. I am thinking to either modify former F2 so that the tank can sit higher and horizontal, or mount the tank over the CG. The latter may be better, seeing that I have the extra weight of the Saito 270 twin up front.
Also, you can see how I have lined up the prop shaft with the centre line. I used a laser level that my dad bought me years ago. Now I have found a use for it!
