RCU Forums - View Single Post - Advice on ARF build.
Old 01-03-2009 | 08:38 AM
Regent
Default RE: Advice on ARF build.
MPW,
It has been my experience that all ARF’s suffer from the same shortcomings. They do not adequately glue the high stress points such as the firewall and gear and they do not fuel proof the engine and tank area.
My suggestions are to reinforce the firewall by adding ¼” triangle stock. Sometimes there may already be some reinforcement there but you should check that it is not just held in place by hot melt glue instead of being adequately glued. I once had a H9 J3 that I could pick out the triangle stock with my fingernail. It looked good at first glance but was completely worthless as reinforcement.
The next high stress area is the landing gear. I have seen many ARF’s that will shed the gear during a normal landing on moderately rough grass. Some members of my club suggest that the lightweight gear acts as a mechanical fuse and will break away easily there by saving more extensive damage to the rest of the airframe. They make a good point, but the gear should at least be able to withstand a bounce or two without parting company.
I don’t know of any company that fuel proofs the engine compartment and tank area. You should have to take care of that little chore as well.
I like to add a few more hinges to the control surfaces in addition to what is supplied with the kit and keep the gaps as small as possible. High speed flutter can either tear off the control surface or jerk the gears out of your servos.
Double check the reinforcement around the fin and stab as well as the wing hold downs. Sometimes these can use a little touch up.
Then go fly and have fun, secure in the knowledge that it should not come apart right in the middle of some elegantly preformed maneuver.
