RCU Forums - View Single Post - Header Breaking - Suggestion
Old 01-03-2009 | 12:13 PM
tomyrcmodels's Avatar
tomyrcmodels
Default RE: Header Breaking - Suggestion
the most easy broken part are that close to the exhaust part. take lot hit and vibration shake. but the end of header tube are not much . can use very thin metal . that's the Idea . the 90 degree part that connect to the flat are 1.2mm . about 3 time thickness than KS uses. make it strong and not easy to broken . compare with aluminium. stainless steel are little difficout to reless the hit , so need quite thickness to build this parts to keep it strong
