RCU Forums - View Single Post - FS One by Hangar 9
Old 01-03-2009 | 02:40 PM
  #1741
Barrrick
Default RE: FS One by Hangar 9
DIRECTING a GREAT BIG THANKYOU to SCTHOLSON
that was indeed the required solution to my FSONE shortcoming. I SINCERELY thank you for that. All that re-setting got to be a bit MUCH.
I forgot to check see if the BELL and the JETHELI come about using the same technique. ( ? )
Now, from your apparently infinite wisdom :is there an "intermediate" setting one can apply in the SIM RATE MULTIPLIER ( under Physics chapter ) ???
the " 100 " setting is way too fast ( I think it is ) I even don't think it reflects any reality.
but " 50 " the next available setting ( which I think is too slow ) does not reflect reality either.
having used G 4.5 in the LHS, these speeds are divided into Beg. Interm. and Advanced......and I believe they are a bit closer to what my RAPTOR actually does at the field.
WOuld you want to COMMENT on this ????
I remain TRULY GRATEFUL.........Richard F. Barr
