ORIGINAL: mike boxtall
Even if you got the saito into the PXT, it still would not be faster than the Revolver with the same setup. The lines on the Revolver are alot cleaner than the pulse, also less dihedral in the wing. For what the Revolver is it moves quick. If you get tired of the PXT get yourself a Revolver and switch the motor. The abilities of the Revo with that same power plant will be sure to impress you as a second more agile and aerobatic plane that has the speed to impress.
Mike,
Yes, for sure. No way was I saying the Pulse could run with a Revolver on similar setups. That's why I'm hawking this thread. The Revolver on a good, fast glow engine will be my next addition. But, if the Revolver with the Power32 on a 4s/4000 will be hotter than the Pulse, I may get a Revolver sooner and gut the Pulse.
Randy
