RE: Welcome to Club SAITO !
Your cam timing must be OK?
But if you have the intake valve just slightly too tight, there is going to be blow back at the carb and the engine is going to be juicy. This will also happen if the valve or lifter are sticking a little.
apparently your cam timing is OK
