RCU Forums - View Single Post - Can u name this part?
Old 01-03-2009 | 11:48 PM
jetmech05
Default RE: Can u name this part?
Yes I can.....the high speed needle valve adjustment is the part that is sticking out closet to you...the low speed needle valve adjustment is on the other side just forward of the high speed the horizontally mounted screw with the spring under it
