have just aquired a Jungmann, fully built rtf less engine.
Will a 90 2s work out or do I need more motor? Any flying tips? I have bipe experience..Astro Hog, and am IMAC level (basic).
Thanks very much,
Ray
Oakville Canada
That depends on the weight of the model. Personally, I'd go with a minimum of a 1.20 4S. I still have mine (the finish is worn out and needs to be redone, it's 14 years old), and it's powered with a Saito 1.50. Mine is finished in fabric and paint and came out at 11.5 lbs. A little on the heavy side, but it flew outstanding and floated in on landings. Follow the setup guidelines from the link above as a starting point and then adjust to suit your flying style. It's an outstanding model, too bad Goldberg doesn't kit it any longer.
FB
