ORIGINAL: advanced2
The composite can use a OS-160 with the mini pipe only. The wood version you can use the full lenght tunned pipe, as the entire belly pan is removable for the one piece wing.
Regards,
Bill Holsten
Team Fliton
Hi Bill . .
Why couldn't a pipe tunnel floor be fitted, as in my Integral and Impact pics below ?? Wouldn't be too bigger jub I wouldn't think . .
The header would need clearance at the side of the fuse . . same as the YS but higher. Would probably need a clearance hole cut across the fuse and the chin cowl join, but no big deal (again, like my Integral).
