RCU Forums - View Single Post - ESC and Rx Location
Old 01-05-2009 | 11:36 AM
Bax
Default RE: ESC and Rx Location
You want the antennas as far from other electronics as possible. You can only test your installation to see if it's working correctly. Otherwise, you'll have to move things around. If you can't obtain the correct balance point by moving equipment, then you may have to add weights in the proper location to balance the model.
