RE: Piston Ring End Gap
Rings are not made from grey cast iron. More like malleable but with less carbon. If you made a ring from grey cast iron it would crack and break before you could get it on the piston. However, there are nodes of carbon, but would only be released when worn through and washed away quickly, not a significant factor.
