RE: recoil unit problem
Ok the instructions are not chinglish just to state as the asiatam recoil comes from germany not china. Did you wire the 3 wires correctly? They should be yellow red and green respectively. Lastly there is an extra long black wire you need to wire to the ground on the main board as per the CD instructions. I have had mine for a while an dit works perfectly.
