RE: Decision
if ya order a hurricane there is a couple little things you need to do.....like with any rc ya need to locktite all screws going into metal, make sure all the screws are tight and your carb settings are set...you also will need to remove the screws that hold the front arms to the steering knuckle...ya need to get screws approx 3 mm longer...then before going back together put a couple drops of tire glue (super glue) on the threads...this will help keeping the screws coming loose and or the threads in the knuckle to become stripped
