Thank You all for your input on take off rates, I did not want an accident on the maiden flight.
BTW I had a shipment damaged bottom wing and TH/greatplanes replaced it no charge within 48 hours.
Insanemoondoggie, and others chime in if this solution does not sound safe. What if you screwed two control horns to the bottom of the SkyBolt top wing, right where the aluminum tabs would have been, heavy duty if you will, like the ones on the elevator, and if you have to glue the screws into the wood, so what. the N struts and the control horns would be holding the wing down. The contrl horns seem to be secure on the elevator and they are under alot of pressure too.
Just a thought.
Joe
