ORIGINAL: Bobt2
a few quick questions. where is the c g located on the fully sheeted wings? the book talks about the rear edge of the sheeting? also how do you retain the hinge pins? i,m thinking a plate screwed into the tips. i want them to be removable.
Balance the plane about the center of the wing tube at first, then afjust to your style of flying. Normally the hinge pines won't come out because the fuselage is there, but if you want to secure them a little dab of rubber glue will do it.
I assume you already have the plane?
TF
