I agree, the manual stinks! We used the manual for the previous version of the ARF which has a different layout. I have updated the manual quite a bit and the new version is located online:
http://www.ohiomodelplanes.com/manua...arf/80edge.pdf
I still need to add some good pics of the new servo installation but I'm waiting on servos to install. Might have them today. But I'll try to explain. First take a dremel with a rotozip bit and cut slots in the hardwood servo supports inside the openings to clear the servo wire grommets on your servos. Servo wires face forward on all three servos. test fit your servos to check for clearance. You can cut the wood all the way through into the tunnel area (about 1/4" thick) if you want. The left elevator servo and rudder servo face the left side of the fuse in the lower double servo mount. The right elevator servo faces right and is installed in the upper servo mount. I hope this helps out and I'll get pictures up asap. let me know if you have any other questions!
