RCU Forums - View Single Post - Servo Question
Old 01-06-2009 | 04:14 PM
exeter_acres's Avatar
exeter_acres
Default RE: Servo Question
ORIGINAL: RCKen
Exeter,
Normally no. Retract servos are different from full proporational servos. The retract servos usually only travel 180°. And if you try to use a normal servo instead of a retract servo it will need to constantly draw power in order to hold it's position, which will drain the battery in a hurry. A retract servo goes to the end of it's travel and then stops, which doesn't draw any power to keep it's position.
Ken
Thanks... I knew about the standard servo and the retract not being proportional... was just curious if you could set the radio endpoints for it..
appears not..
Thanks!
