RE: AMR 50 Trainer
Tonight I framed out the left wing section. The toughest part was setting the 1st rib with 1 degree dihedral. After that it was an easy task. The pics are the bare frame, then wit the flaps and ailerons in place then for size comparison a Rascal 110 wing on top of the 50Trainer wing. As you can see the wing on the 50Trainer is much more significant. The wing is tacked together with thin CA at this point. Tomorrow I will add Titebond II glue to all the ribs and let it dry while I am building the right wing.
