RE: Ryobi differences... Comments??
Another item I didn't mention, the backplates you describe as be the best for you can be found on either short or long shaft engines, and neither one will fit the smaller case. Keep looking, and you will eventually find a "BEEFED UP" con rod if you fine enough engines. That may be my next exchange to go to a higher RPM range. FLATHEAD 4
