RE: Aresti question
Now the pull to the 45-degree line from the vertical line should be the same as the radius you used to pull to the vertical line so lets say it took you 3 seconds to pull to vertical, then the pull to the 45 should be three seconds
This statement is incorrect. Family 1.12, Fig. #17, in the IMAC F&JG states radius A, B, and C in a sharks tooth need NOT be the same.
